Spreadsheet (Blind Only)
Spreadsheet format is available only in Blind mode. It is useful for viewing channel data and trends for multiple cues, submasters, palettes, or presets at one time. Cues and record targets are displayed on the vertical axis, and channel and parameter data on the horizontal axis.
Note: Since this is a Blind-only view, changes made in this view are immediate and do not require a record or update.
As with table view, spreadsheet format allows you to choose exactly which parameters you want to view. Parameters can be expanded/ suppressed by holding [Params] or [Data] and pressing the desired parameter buttons in the CIA. Category data is not available in spreadsheet, but you may hide all parameters of a specific category by holding [Params] or [Data] and pressing the desired parameter category button. On Element 2, Ion Classic, and Element Classic, you will need to use [Data].
To toggle between viewing just the intensity information and other parameters, press [Shift] & [Format].
The label column can be hidden by selecting the Suppress Target Labels option in the Live and Blind Tab Configuration.
